Pinouts of Connectors
Nokia Pop-port pinout
connector wiring
bookmark this page
This external connector for Nokia 2112, 2115(i), 2116i, 2125i, 2126i, 2128i, 2270, 2272, 2280, 2285, 3100, 3105, 3108, 3120, 3125, 3200, 3205, 3220, 3300, 3570, 3580, 3585(i), 3586(i), 3587(i), 3588i, 3589i, 3220, 5100, 5140, 6011i, 6012, 6015(i), 6016i, 6019i, 6020, 6100, 6101, 6102, 6108, 6200, 6220, 6225, 6560, 6585(i), 6610, 6610i, 6800, 6810, 6820, 6822, 6200, 7200, 7210, 7250, 7250i, 7260, 7360, 7610, 9300 and some other models. full pinout.
14 pin Nokia pop-port cellphone special connector layout
14 pin Nokia pop-port cellphone special connector  at the cellular phone
The port contains signals for handsfree microphone, stereo speakers, FBus Rx/Tx or USB signals for the phones supporting them, power output for feeding the accessories that don"t have their own batteries, and the Accessory Control Interface (ACI), a bidirectional serial control bus for connection of phone accessories, with a proprietary protocol.
Pin
Number
Pin
Name
Description
1VinCharger input
2GNDCharger ground
3ACIAccessory Control Interface
4V OutConnected to pin 3 in DKU-2 usb data cable
5USB VbusAlso act as USB power detection? Should be connected to USB pin 1 in usb data cable.
6FBus Rx/USB D+USB exists in some models only*. Should be connected to USB pin 2 in usb data cable.
7FBus Tx/USB D-USB exists in some models only*. Should be connected to USB pin 3 in usb data cable.
8GNDData GND
9X Mic-Audio in - Ext. Mic input negativ
10X Mic+Audio in - Ext. Mic input positiv
11HS Ear L-Audio out - Ext. Audio out - left, negativ
12HS Ear L+Audio out - Ext. Audio out - left, positiv
13HS Ear R-Audio out - Ext. audio out - right, negativ
14HS Ear R+Audio out - Ext. audio out - right, positiv
GNDshield GND in cavities
* Nokia N70, N90, N91, 3230, 3300, 6155, 6170, 6230, 6230i, 6235, 6255, 6260, 6630, 6650, 6670, 6680, 6681, 7270, 7600, 7610, 7700, 7710, 9300, 9500 and some others. It"s possible to connect this phones directly to computer USB port with straight cable (see DKU-2 cable above).
This external connector may be found on variety Nokia cell phones.
Some Nokia cellphones are built with two connectors - external (this) and internal, so it may be 2 different connectors and 2 different pinouts for them.
Related Links:
Pinouts.ru > Nokia cell phones ports pinouts listing >  Pinout of Nokia Pop-port and layout of 14 pin Nokia pop-port cellphone special connector
Document status: correct
Source(s) of this and additional information: NokiaPort.de, Bruce GSM pinout 18 report(s)
Last updated at Mon May 29 2006. Add your comments to this document. Is this document correct or incorrect? What is your opinion?
[Discuss at the forum] [Back to index] [Add new pinout]
This page contain parts under Copyright © 2000-2006 by pinouts.ru team.
No any portion of this webpage may be reproduced in any form without visible direct link to this page provided. Webmaster permission required in any other cases.
Efforts have been made to ensure this page is correct, but it is the responsibility of the user to verify the data is correct for their application.
49164 hits since March 4, 2005
